Doral 360 electric panel
Slamm06
I have a Doral 360se with 2 30amp shore power connections, main 1 and main 2. Today only main 2 is working, I've confirmed the shore power is good up to the boat connection. But between the boat connection and panel a breaker might be tripped. Doses anyone know if there is a breaker or fuse between the panel and shore power connection and if so where? Any other ideas to try?
Thanks
gaugeman
Re: Doral 360 electric panel
I only have a 250SE, but there should be no circuit breaker between the hull connection and the electrical panel. You may have a bad circuit breaker.
Taylor Made
Slamm06,
On my 08 Intrigue, there are two main breakers located in the storage trunk in the transom near the shore plug inlets.
On my boat they are not easily seen unless I stick my head in there and look around.
on my 06 Elegante, i can access the rear of the shore power cord inlets from the engine bay. i would first measure voltages back there to see if the inlet jack still works. one of the first things i did was replace both those inlet jacks, just in case.
or get yourself one of those AC power voltage detector pens for 8 bucks and start tracing.
the power panel itself should be easy to access. it should be easy to see if power is reaching the back of the panel.
Slamm06
It turned out to be a bad circiut breaker, thanks everyone for your ideas.
