Dose my factory manual exist?
Status
Not open for further replies.
saltlife50
Ok so I have been trying to find the factory manual for my engine and can?t find it anywhere. My engine is a 92 OMC v115slend (yes it?s a quiet rider) if anyone knows how I can find one that would be great.
I have spoken with a local mechanic (Panama City, FL) and he told me my engine and the Johnson/Evenrude of that year are the same. Does anyone know if this is true? And if so do you know the model number of the Johnson/Evenrude I need.
Thanks, Chris
F_R
Re: Dose my factory manual exist?
Outboardbooks.com has books older than a certain cut-off date. Newer than that date, you get them from an Evinrude dealer. Sorry, I don't know what that date is.
bob johnson
Thanks, Chris
I wonder if you wrote your number down correctly...of the two sites I use to look up motors and parts, neither had a listing for a 115 SL motor. they did list an SL motor in 100 HP and it had a V on the front as well...
SL usually means special styling in a long shaft...usually a white motor..
but i had a motor that i couldnt find as well...so I dont doubt an odd ball got through that doesnt show up in the standard listings..
I had a 2001 johnson 50 hp with a V in the model number, but the V was after the "50" and before the "S".....
I had seen a few listings of models with the V after the hp, but none in 50 for my year
good luck
bob
clanton
Go to BPR parts web site, click on Evinrude, click on Quite Rider. Click on your year.
The V4 engine is a cross flow
saltlife50
Dumb question maybe but hear go?s. how can I tell if my motor is a 60 or a 90 degree?
bob johnson
model number first off
the shape of the motor cover...
90 degrees had two latches in the back, 60's had only one
the cover is kinda triangular shaped on the 90's and more rectangular shaped on the 60's
then i THINK( not 100% sure) all the 60 degree motors have covers over the flywheel, but on the 90's you can see the flywheel
hope that helps
what is the model number?
bob
ezeke
The engine is a crossflow so it is 90 degrees.
You have the model number correct in your opening question, "V115SLEND".
wilde1j
'97 and newer motors - manuals from BRP Evinrude dealer.
'96 and older - outboardbooks.com, Ebay, etc.
F_R
"V" means it was built for a boat builder. Does it have a different name, other than Johnson or Evinrude? Whatever the difference, it is probably the same under the skin.
bob johnson
anyone have a photo of a QUIET RIDER motor???
what is special about them??
bob
saltlife50
As far as I can tell the motor is exactly the same. The only difference is the way it is mounted, the motor rotates within its own axis and has a cover that mounts to the boat and covers the engine to make it quiet. And yes it works very well so well you really can?t tell the motor is running. boat 002.jpg
vincep
I have an OMC Quiet Rider V115SLETS that i'm having problems finding the manual for as well. I can even post my serial number if it helps.
jbcurt00
Please dont hijack old inactive topics
Please start a.topic about your boat and its manual. However, the answer is likely "No, theres not a manual for your boat'
Might be 1 for the motor though
Closed
Status
