DP identification
mrscheib
I have a 1988 Skip Jack 28' FB. It is powered by a AQ271C. I am having trouble identifying the outdrive. I've attached a picture. I believe it is a 280 or 290 but not sure. Any help would be appreciated.
captmello
Re: DP identification
It looks like a 290dp, It has power trim right? With a trim gage at the helm?
Maclin
Since the engine is the AQ271C then it is definitely a 290DP.
bruceb58
Looks like a 290 because of the hook up fork.
for 1988, it should be a DP290A. It looks just like mine.
mrscheib
Yes it does. I'm a lucky man as my son's friend just gave the boat to me. And it has a newly re-built engine. Can't wait to get it out on the water to catch some halibut.
Thanks again for your quick replies!
make sure you do the basics, check the drive oil level, impeller, etc.
the drive oil is synthetic gear lube.
welcome aboard.
