DP-SM tilt hose
cptbill
I could use a little help here. I've got a 2000 Larson Cabrio with twin 5.7 GSI PWTR engines and DP-SM outdrives. I've been trying to look up the part # for the hoses that run from the block behind the gimbal housing to the tilt rams and the part # for the rams. Problem comes in when I try to look it up in the VP parts catalog I can't find a page for it (you know the one with the parts broke down and numbered then you scroll down and find the part #) If any one can help me out with a link it would be very much appreciated. And before you ask yes I have been to my local VP dealer and have ordered new hoses but they are on intergalactic back order and I don't have enough pieces left to get the made so I'm going the ebay or aftermarket rout
Yegboats
I don't have access to the US volvo parts site but I've seen screen shots. It looks similar to what dealers have access to in Canada.
Basically under Marine drives and transmisison scroll down till you see SX-A dPS-A dPS-B' DPS-B1...... so on
once there click on Transmissions and scroll down till you see trim pump systems at the bottom. Hope this works.
Fun Times
I don't have access to volvo us website but on your US website try searching under clicking this link won't work. Marine Drives & Transmissions > SX-A; DPS-A; DPS-B; DPS-B1; DPS-A OXi; DPS-B OX; DPS-B1 OX; FWD; SX-A 1.43; SX-A 1.51; SX-A 1.60; SX-A 1.66; SX-A 1.79; SX-A 1.89; SX-A 1.97; S > Transmissions or XDP-B; TSK X-B; TSK X-BLT; TSK XHP-B; TSK XHP-BLT; TSK XXP-A; TSK XXP-ALT; TSK XXP-D3; XDP-B 1.78; XDP-B 1.95; XDP-B 2.32; XDP-B-D3 2.11; XD
Then under trim pump. It's way easier, and accurate if you had a transom serial number. Or even an engine number to look up all 3 serial numbers. I don't know if that search feature is available on the US consumer website though. I've seen links from the website and it seems better than what we have access to here in Canada.
Yegboats, Just so you are aware, The link you provided earlier is/was for Volvo dealers use only and is password protected...Your dealer I believe should have something similar though.:encouragement:
If one should click on the link in my signature line below, it will take you to Volvo's parts which is powered by iboats....http://www.volvopentastore.com/
cptbill, Here's your engine parts, http://www.volvopentastore.com/Marin...view_id.765176
And your drive parts, http://www.volvopentastore.com/Marin...view_id.765076
But in order to help find the correct trim cylinders and hydraulic trim hoses you will need your Transom Assembly model number. The number may resemble or may even be like the one in the following iboats link. His number is TSK Sx-MLT....http://forums.iboats.com/forum/engin...ic-hose-repair
If yours is the same number then here would be the parts guide you're looking for. http://www.marinepartseurope.com/en/...t-7746040.aspx
But you need to confirm your transom model number to try and help ensure we're looking for the correct parts. Also write down and post your serial numbers just in case Yegboats has access to Volvo's website as it may help too.:thumb:
cptbill
Big Thank you Yegboats! This is just what the doctor ordered. not going to be able to get the transom # till my gests leave but I'll get back to you.... ​Thanks again my local VP dealer is a little tight with part #s
Yegboats
Glad we can help :) I just wish I had access to that wizzy US vp site.
cptbill
Just so everyone Knows the US VP site does not show or list anything for the tilt rams or hoses, but thanks to all
Fun Times
Were you able to find your transom model number such as the TSK Sx-MLT example posted above? The ID plate could be inside the boat behind the engine in the vicinity behind the steering actuator and resemble the following information, http://www.volvopentastore.com/mall/template/store/volvopenta/help.html
Even without the ID plate, here should be your trim cylinders and other transom assembly hardware/accessories part numbers to go by,
http://www.marinepowerservice.com/B...D=122673&parent_cat=450458&parent_cat1=450463
http://www.marinepowerservice.com/B....cfm/parent_Cat/450458/parent_Cat1/450463.cfm
cptbill
Have not gotten the transom # yet but was able to call a colleague in another area and he checked with the VP dealer That is a friend and confirmed the part #s and they match the euro VP #s, But the peps leave in the am tomorrow and I can double check
cptbill
Almost forgot, they also match the #s from the marine power service thanks funtimes
