DP-SM transom assembly electrical
Fireman78
When I was redoing my transom the grommets and wiring got messed up that pass through the transom. I’m trying to order replacement wires. I found the trim sensor and grommet but I can’t figure out what the other wires were for(I’m not near my boat). It’s for the hole on the left though I believe. Check the picture. I thought it was for the anode corrosion system?
dypcdiver
Do you have the active corrosion unit at the base of the Transom Shield?
Fireman78
Yes I do have the active corrosion! Thanks for the heads up! Let me see where I can find to order the wiring
