loco
Thread starter- Joined
- Apr 25, 2010
- 154
Hi all,
Going to service my own engine this year which is pretty straightforward, but would like to do the drive leg too. There's nothing wrong with it, so just needs the oil change, etc. So far, I think I just need to do the following:
- Open up the drain plug at the bottom, take out the dipstick, drain the oil. Replace the seals on the plugs
- Swap out the anode, re-grease the prop shafts, etc.
- Clean it all up, anti-foul the leg and props.
The bellows were swapped out less than 2 years ago - I'll check the state of them, but suspect they'll be fine.
Anything else I should be taking care of/attending to while I'm at it? I'm hoping to do it between tides, so taking the leg off, etc. isn't something I'd be able to do in the time....
Thanks in advance!
Thanks in advance!
