I have a 1966 Gulf Stream. I pulled the Mercruiser motor to have some work done. The front motor mount bolts pulled out from the floor. They were rusted and wet. I Removed some wood around the mount area down to the hull. I took some foam out around the area where I removed the wood. Water is comming into the area where I took the foam out??? There is only one drain for the bilge and none for the hull??? I bought the boat June of this year. The previous owner said that the boat was tilted up during storage. Apparently it wasn't covered to protect from rain. I really don't want to undergo any real major modifications that would include making another drain for the hull. I'm using a shop vac to remove the water and a blower to dry the moisture. Also I intend to keep a heat lamp on to try and further dry out the wet area. If any one has any suggestions that you may have to address this problem, please let me know. I don't have deep pockets, but I have lots of time. I really want to make this "New Old Boat" something I can use and enjoy.. Sorry for such a long note...Thanks
