drain plugs on block
Colliemcc
Could some one please advice me to were th
e two brass drain plugs are on the block of my engine.
Its a volvo penta 4.3 gl. Its a 04.
Thanks Colm
captmello
Re: drain plugs on block
They're down low in the center of the block, just above the oil pan. You'll need to drain your exhaust and cooling system as well.:)
Lou C
One is just in front of the starter, the other is near the oil dipstick tube, I use a small adjustable wrench to loosen em, and when I put em back in I put a little motor oil or grease on the threads so they come out easy next time....
Colliemcc
I have drained all the other bits. I will do the block 2m thanks for your help.
Colm
Don S
Did you get the intake manifold drain?
