Drain points on 1984 GM 5.7L engine on 1984 Chapperal stringer
DeltaCougar
I know my motor has 2 small rubber drain caps and 2 large drain caps. I can't find the 2 large caps. Anyone know where the 2 large caps are.
Howdy
Have not seen folks list small and large caps. There would be 2 block drains and the maybe 2 exhaust drain plugs.
If you can provide a serial number I can look closer to what you have possibility
muc
"Retired" Association of Marine Technicians...
@GA_Boater
Looks like this might belong in the OMC section? Stringers had rubber caps if I remember right.
