drainage around stringers. should i drill?
JT!
the floor is ripped out and there was obviously a floor rot issue previously.
the stringers seems solid & sound, but need to be re-glassed in.
the floor is basically a grid of 2 stringers and 3 cross brace struts.
should i put little sections of 1" pvc tube to help drain each section, inline with the keel? or would that interfere with intended design?
oops!
Re: drainage around stringers. should i drill?
nope....wont hurt at all.......just make sure the pvc is sealed so water cannot get behind the pipe and into the strings.....
dont go overboard on the drainage holes tho
