bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
Didnt have time to go to the gas station before I put my boat on the river . I needed to adjust the trailer and try the boat out again before the duck hunting opener sat.
so i grabbed the old boats gas can which has been sitting since feb of this year.
the boat ran across the river and then we putted around a creek inlet and back out into the river and then I took her up to about 20 MPH ( 3000 rpms ish) for the trip back across the river and the motor coughed and died..
pumped the primer bulbs( 2) just for going through the motions and eventually it fired back up. then a minute later it died again for good..
I could smell gas the whole trip
ok paddled with one 7 foot oar for 2 hours to get back.
at the dock i checked the spark..all had spark( 1995 115 johnson)
did my trailer adjustments and went home. once home i checked the compression on the three cylinders i could get the gauge into all 125.
ok questions
could the bad gas have let me run across the river and then caused my motor to die?
second, I have had a slight l seepage of gas out of a small plugged port in the side of the starboard carbs... so much that you could wipe it off and in a second or two it glistens with wetness again..
well between the two carbs i can see( cant see that part of the port carbs)
i am getting enough gas in the cowling that when i tilt it dripps out on to the midsection and tnt pump.........can i drain the carb bowls with out taking off the cowling??
because i want to try and glue that seepage shut, till after next week when i can take the motor in to have the carbs looked at.
I have a water seperator/fliter, and an additional in line fuel filter!!
thanks
bob
ok questions
thanks
bob
