Hi I am new to this forum but have been following it ever since I purchased my boat. My question comes kind urgent since winter is fast approaching and in need to winterize. Last year I drained the raw water from my system and added antifreeze where i removed the thermostat until filled. I would have just left the system dry, however my engine block has two cooling plug drains whereas one is a torx head and has been stripped. I drained the one side and was unusure wether though that drain, the other side of the block would have drained as well through only that one hole. Therefore I added antifreeze to the block just in case. My question is wether the engine block drains completely through 1 drain or whether the block has two separate cavities. Im trying to save on antifreeze and thermostat gaskets
4.3LX Mercruiser 1994
