Draining exhaust manifolds
doral1985
Whats the normal after a run with the 3.8l , do you drain the manifolds between outings or leave the water in them?
Howard Sterndrive
Re: Draining exhaust manifolds
leave fresh water in them except in the winter
jerryjerry05
Draining the water from the manifold will accelerate the rusting.
If you run in salt water, then flush and leave the fresh water in there.
When you winterize, make sure the manifolds have antifreeze in them.
