Draining my 5.0 305 800 stringer
THE BEEF
Just a quick question. On my 305 800 stringer I want to drain it tonight to be safe. I think I open the 2 drain cocks on the block and pull the rubber caps off the exhaust manifolds and raise the front of the motor with the trim motor.
Anything else?
Thanks
Beef
Re: Draining my 5.0 305 800 stringer
Ayuh,.....
As you know Beef,..... I don't do OMCs.......
But,....
I'd go ahead,+ pull the Big hose off the circulating pump too.....
That'll hold a Qt. of water sometimes......
Btw,.......
I found,+ installed my Whistles........
Even can filling the tanks at the dock results in a nice steady Whistle........
I Love'm..............;) :)
wire2
Yes!
Undo the water hose on the power steering heat exchanger, (near the distributor).
When you have the brass plugs out of the block, poke a piece of wire in the holes to make sure it's not blocked with rust.
Boomyal
Yes!
Same with the plugs in the manifolds. I did not do the wire thing one year and paid the price. Engine and mani's.
