Is it OK to drain the water from the engine into the bilge area (with the plug pulled of course) for winterizing purposes. I have a manual and it says to use an appropriate drain pan, Yea, Right. I can't get a drain pan down there, and when I found a small one that barely fit I made a bigger mess trying to wedge the half full plastic container out to dump it. Which I had to do many times. Thanks
