chriscraft254
Thread starter- Joined
- Jun 4, 2011
- 2,445
Re: Dress her up or not? Opinions wanted.
Thanks Mark. I will have to double check with Rob and see if the remotes will conflict with each other.
I will probably have to install a completely different rf contoller with remote. I am assuming each rf controller has a different code signal like a tv remote or similar. I simply don't know yet. Will let you know when I find out something. It would be more expense but the seperate systems is really what I want if they don't interfer with each other. I plan to add a couple feet off the string inside the anchor locker as well as under the trim around the wa.
I will keep you posted. Probably will be working on the trims tmrw. funds are slim, so I will probably install the teak first then get the lights when I have some better cash flow.:redface: I still don't know if the teak will bend the way I want it to. Will try to test that in the next couple days.
Budd,
i meant to add the extra dimmer before the rf on the front string, so you can dim it while driving
if your rf can dim independantly than just hook it up
i'm trying to figure how the remote will know which string to change?
i guess if the remote eye were in different places for each string it wouldn't be an issue
at your advice i bought two strings.
although a little directional each remote will work both strings.fyi
i will be installing here in a month or so(when the shops all done with the drive work)
so i'm watching that trim project closely (like it so far)
cause i dont have any easy mounting loacation like your rod holders,
i will likely have to add some trim or the lightbulblbs will be seen
thanks for all the info
and the inspiration
great work
Mark
