TwoRivers
Thread starter- Joined
- Mar 10, 2010
- 354
What do you guys use to dress the threads of the bolts that attach the lower unit to the mid section? The manual says to use OMC gasket sealer. Reading numerous threads I discovered that the Permatex Aviation gasket sealer is the same? I picked some up and it looks like the old shellac goop from yesteryear?
Earlier I started a thread when I broke two bolts while removing the lower unit of my 89 70hp Johnson. Thanks to your help I was able to remove the power head and take the mid section to a shop where the bolts were drilled and heli-coiled. So now I'm at the point where I got the power head and the mid section re-assembled and I'm ready to install the lower unit.
I'm thinking that whatever the factory used to seal the threads caused the bolts to break, The motor was never in salt water.
Anyways, looking for some advise before I tighten the bolts.
thanks
rob
thanks
rob
