FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
im getting ready to drill and tap a bypass cover for a conversion to single line fuel pump, from what i can tell i need to use a 15/32 bit to drill a hole for a 1/2 npt thread? does that sound right?
Another thought. Not sure exactly what you are doing - but, 1/2 NPT (National Pipe Thread) is thread for 1/2 inch pipe - which is about 3/4 inch OD. Are you sure that's what you will be using?
1/2 x 13 NC (National Coarse) tap (for a 1/2 inch bolt) takes a 27/64 hole - which sounds more like what you are looking at. Are you installing a bolt or a piece of pipe?
thats why im leary of drilling the hole!! the fitting i have will fit in a 1/2 " hole on a gauge, it threads loosely into a 31/64 hole in the same gauge, and the 15/32 hole seems like it would be the one for the right drill size for threading to accept a 1/2" npt fitting. ??? i do see there are different sizes for different materials, and the charts show different things.
See http://www.newmantools.com/tapdrill.htm for both tapered and straight pipe thread specs. If your fitting will fit into a 1/2" hole it is not a 1/2 inch pipe fitting. Pipe fittings are based in internal diameter. The threads are on the outside diameter - for example 1/2" pipe is about 3/4" in outside diameter.
A 1/4" x 18 npt tap takes a 7/16" hole (real close to 15/32"). 1/4" pipe would fit loosely in a 1/2" hole (and maybe a 31/64 hole).
i had a couple of fittings laying around and just measured them, but i did pick up another one today at uap, and its the same as the others as far as size goes, but does say on the package, 1/4" MNPT.
Ah. The old pipe-thread/fastener-thread confusion I've made many return trips to Home Depot as a result of forgetting the difference (how can that be 1/4 inch thread when it's almost 1/2 inch in diameter ... ). I still have to grab a fitting with the size marked on it and do a trial fit just to make sure I get the correct hardware/drill/etc.
Yep, you've got a 1/4 inch pipe fitting and you can drill the hole for the tap at either 15/32" or 7/16".
