checkeredflags
Thread starter- Joined
- Aug 6, 2007
- 4
I have a 16" aluminum boat and I need to drill two holes through the aluminum 1/2 " in diameter in order that I can install two extra bolts to secure a 25 horse engine. There are two bolts going through the transom above the water line that go through the wood; however I need aditional reinforcement and this will require that I drill two holes through the thin aluminum below the wood transom to bolt the lower portion of the engine mounting bracket. I thought I would use a thin piece of steel on the inside like a steel plate...drill the hole and run 1/2" bolts through the aluminum and the plate and bolt it down. My concern is leakage since this will be right at or a bit below the water line...not sure what to do.
