glenn property of pam
Thread starter- Joined
- Feb 17, 2012
- 2,906
ive been putting this off for a while but its time to drill the holes for the speedo and transducer in the new transom. im thinking off drilling a 1/2" hole for the speedo then either pb or 3m 5200 a carbon fiber tube about 3/8 in the hole so there a small amount of room for the pb/5200 to seal the carbon to the wood then feeding the speedo tube throught the hole and putting a 90 degree plastic fitting so the tube runs down the transom then sealing the inside of the hole with silicone before applying the cover piece this way the tube could be removed in years to come with out the seal to the transom inside begin ruined. the carbon fiber is from a old fishing pole that had a broken end i was just going to sand the shinny off it as its tappered over 12' so one piece will be the right size.
do you guys think this is overkill.......im just worried that if i straight drill put speedo tube in and fill with 5200 theres a chance in years to come that water is going to get in the transom.
