Drippy drip under outboard?
made in china
SO, I noticed tonight that after sitting a few eeks in the same spot, there's a drip spot under the prop of my '90 Merc 115. Can that be considered normal? Never owned a OB boat before, not sure if it is "normal". Maybe I should pull the prop and check the shaft seal?
achris
More fish than mountain goat
Re: Drippy drip under outboard?
It may be just some oily residue from the exhaust housing... and normal. You need to determine what the drips are... gear-oil or thick burnt engine oil.
