tampa boater
- Joined
- Aug 20, 2006
- 22
Hi There - Saw the Sticky on the bulletin related to "Drive leaks down, trim system does not hold pressure" - Bulletin 44-5-2A. It indicates it applies to "All DP-290 with Power Trim", however the pump in the picture shows the later model and I have the "earlier model" as pictured in the 2 attachments. My system is exhibiting same behavior.
Does anyone know if the procedure will work on the earlier model pump - and, if so, where are the up/down valves located?
edit - just to clarify - I have outdrive model Volvo DP-290a. They year I believe is 1990. The engine is V8 5.7L Volvo around year 2000 on new block. And my symptom is drive leaks down quickly with no external leaks (new seals installed) - don't know if it worked properly prior to new seals - was leaking when I purchased the boat. Drive will not trim up when under load at planing speed - though the electric motor does engage (I can see voltage meter go down but trim angle does not change on gauge) - i.e. works when not under load / at idle but sinks down quickly and the internal leak / bypass is such that it won't trim up at all under load at speed. It will trim up in forward at slow speed but sinks quickly all the way down within a few seconds.
Thanks! - Steve
Thanks! - Steve
