FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
If water was mixing with the gear oil, should I be able to see it at the reservoir mounted to the side of the engine? Would it look frothy, as you'd expect when water and oil mix?
As AD has said above. Even less likely if the tank has the usual issue when it’s blocked by crud in the bottom and of no use anyway. Often the case unless it’s drained and cleaned out too. Always amazed at the number of boats that never have the full system drained down. Just the drive.
Is it worth having at all? This is the first boat I've owned and/or seen with it. If it is of no real use, then maybe having hoses and reservoirs that could leak are worth removing?
Yes, in all cases if there is a leak then the reservoir amount will lower. Check when cool
The bottle has a one way valve in it which allows air in but not out. So when drive heats up it keeps the drive totally full and under pressure due to the heat build up. The pressure will help keep water out
