drive problems I think?
Thuffjr
Hello All
Being so close to the season I decided to fire up my 87 mercruiser 3.0 w/ alpha one out drive
It took a bit to get her going and when she fired up I tried to put her into gear the engine would throttle up but no shifting. Usual I get a bit of a clunk when it shifts but nothing today just revs the engine, and when i try reverse the engine stalls.
Could this be a serious drive problem?
thank you for any help.
Re: drive problems I think?
Ayuh,... More than likely, it's the Lower Shift Cable.....
Serious enough it Needs fixin', but not the End of the world....
Don S
Sounds like you too have a lower shift cable problem.
A cable with cracked rubber coating that gets rusty and sets all winter usually binds and needs replaced. Happens all the time.
HT32BSX115
Howdy,
well it could be......but it's more likely a shifter or lower shift cable issue.
If you haven't already, you should go up to the top of the forun and look at the "Stickies" for the manual and other info there.
Also, with the engine off and the key in your hand, have someone slowly move the shifter into FWD while you turn the prop backwards.....and again into REV while you turn the prop forward.
See if the prop stops when shifter goes into either gear.
(if you turn the prop the "right" way, there should be a clicking noise")
Thuffjr
Just went back out looks like my lower gear drive is shot i pulled lightly on my prop and entire shaft comes out 1/4 to 3/8 of an inch. Im looking at my pdf manual an what i thisnk is comming out is the bearing retainer nut? Does this sound right sorry im far from a boat mechanic so I don't think i have the proper terminology here is a pic.
Ayuh,... You didn't change the outdrive oil as part of winterization...
It had ALOT of Water in it,...
I dare say you're Right though,...
You need a New outdrive...
Thuffjr
I had the drive all the way down for the winter but everything was fine in october when i put it up for the season. What would cause this?:confused:
Thuffjr
Of course I do Thats what I was expecting to here but hoping not to.
Thuffjr
Will I be ok just replacing the lower drive?
fishinpa
H 2 OHHH in your gear oil
as stated above !
fish
Bt Doctur
May be able to replace just the lower but with that much water I`ll bet the upper is quite rusted inside too.did you change the drive oil when you winterized it?
Thuffjr
I did not, I'm very new to boating and didn't find out I needed to until...well now
Guess I'l Bust Out Another Thousand
Bt Doctur
It`s sitting in possably a SEI shipping crate saying the upper splines are damaged. That can ONLY happen from a severe bottom strike leaving the gearset and bearings questionable.
I`d avoid that one.
What you need is to go to the "Adults section" and get the manual .download it and start reading
Ayuh,... Thruff,... You should be lookin' into SEI replacements....
Probably Cheaper than fixin' Your's....
Btw,... Upstate is a vast area,.... Where abouts,..??
Thuffjr
very close to lake george
What do you mean by SEI?
