Drive removed for the 1st time, gimbal aligment inspection
Kubaat3lover
Thats my engine mounts, its Caravelle 2005
alldodge
They have been adjusted before because the tabs on the bottom have been bend away from the nut. Its ok to leave them that way if you do annual or semi annual inspections.
Not for certain but think the nuts are 1 1/8. Loosen the top nut a few turns and then rotate the nut counter clockwise to raise the bottom nut up.
Kubaat3lover
Thanks I will do that for sure before summer, by the way. What tabs Youre talking about?
Thanks again for your help! Im doing also Carb rebuilt process now.
Kubaat3lover
Should I bend it again after adjustment?
I have sprayed it with some WD40
alldodge
I wouldn't unless your going to let it sit without checking for several years. I pull the drive every year and check alignment and do maintenance. If you do it every year or every other year, I wouldn't bother. It doesn't hurt to do so, but if the top nut is torqued down real tight, the bottom will not move
Kubaat3lover
Im gonna inspect drive anually, should I turn it 1 full turn? 1/2? 1/4? Whats the way to do it? Thanks
alldodge
Do how ever you would like, its all adjusting to a specific point of 2 fingers in/out
I would do one turn on each and then look to see how the marks change. It can always be reversed but I'm just guessing from what your showing.
Kubaat3lover
Thanks, When doing research for Ujoints with external clips replacement Ive found that my Yoke looks very similar to Volvo Penta yokes (and Ujoints) , sorry for poor quality pic of my yoke:
and heres Volvo Pentas Yoke
is it possible that someone swap it - if yes why someone do that? Is it interchangeable?
Quicksilver 864282T looks the same with GKN stamped​
Thanks!
Kubaat3lover
Ive got the one with external clips... 200$ per Ujoint!!
Any chance to go for inside clips or impossible?
alldodge
Don't know of anyone who has tried to change. Don't think its possible because of dimensions. Could buy one U joint and see if it would work
Can also buy Sierra equivalent
Kubaat3lover
Do you remember The number? I’m not from US So I have to order it online or find other number
Rick Stephens
Here's the Thread. I used the Moog crosses in my '93 Alpha 1 Gen 2.
