I have a 1996 120 HP Force. It currently has the extra long shaft with the "5 spacer. It sits to low in the water on pontoon. Can I replace the "25 inch shaft with the "20 in shaft? From what I see it is just a matter of removing the spacer and replacing the studs with shorter ones and remove the shaft install shorter one and put it back together. But is there more involved that what I am seeing?
