NHGuy
Thread starter- Joined
- May 21, 2009
- 3,631
I chickened out on installing my new u-joints and took my drive to a car & truck drivetrain shop to have them installed. I'm now a little concerned that it may have been a bad choice. When I turn the drive shaft at the yoke I hear a rubber squeak like a dry seal. I turned the same piece before I brought the drive in and it was nice and quiet. Is it possible the yoke may be too tight causing that sound? I'm a bit concerned that if I start the engine something bad could happen.
I did some reading and found the connection is supposed to be torqued to 200 ft lbs. Maybe the guy who put in my cross joints has a big mama impact wrench. Have any of you had a squeak when hand turning the drive gears?
