Re: driveshaft stuck in powerhead
Thanks for all the ideas,a couple of thin chisils did the job.I had it running in a plastic tote with a mixture of salt away and water,I've done this before and it really clens the cooling system,just make shore the water doesn;t get to warm.While it was running it stopped pumping water,when I took the pump housing off the impeller key was missing and the shaft was just turning in the impeller.I've worked as a marine tech for quite a few years and never had this happen before.The key is the wide flat type,where did it go?Paul
