Driveshaft
jessie11
1992 Mariner 150 Ser# 0D124111<br />Removed lower unit to inspect water pump I installed about 6 months ago, all was well. Went to reinstall the lower unit and had a awful time getting the driveshaft spline to line up with the powerhead. With a flashlight looking from the bottom of the motor I could see a round ring like object blocking the bottom of the crankshaft spline where the driveshaft goes into. Got a mop handle and stuck it up there and lined the ring up and installed the lower unit with no problem. Any idea what this was? I have pulled this lower unit several times with no problem and ths is the first time I have ever noticed this.
Laddies
Banned
Re: Driveshaft
It was probably the seal ring that seals the driveshaft inside the crank
jessie11
Re: Driveshaft
Laddies,<br /><br />Looking at diagrams this is what I thought it was too. How bad a problem is this. Is this a major failure waiting to happen if not quickly repaired?<br /><br />Thanks for the replies.
oceanboy78
Re: Driveshaft
Hi there<br /><br />Its really important to fix this<br />The same thing happened to me and I didn't know about it.<br /><br />The next time I pulled the shaft off, the bottom of the crank had corroded out. <br /><br />I had to get a secondhand crank shaft and the whole motor had to be pulled down to install it
