Re: Driveshaft
I don't consider that a hijack--it is a logical question related to the thread and quite relavent.
In the first answer I recommended to "firmly rap" the top of the crank. It was either not read or mis-understood so I got a little more aggressive in my second reply. Also, I recommended using a brass or aluminum drift to take up some of the force and preserve the threads.
Brinnel is a rating of the surface hardness of a metal--usually steel--measured by pressing a hardened ball (bearing) or a rounded cone into it. Depth of penetration is brinnel number. Brinneling is the act of denting the races of a ball bearing or others by applying excessive impact forces. Bearings are "dead" hard and can withstand significant pounds per square inch forces. Indeed, they are amazing pieces of equipment. It is no accident that during WWII, the bearing factories in Germany were considered primary targets for bombing.
Think about the impact loads when an auto hits a pothole at 20 or 30 mph. The front suspension members may bend and even the spindle may bend, but the front wheel bearings will usually be ok.
BUT, Yes, it is possible to brinnel the bearing by using excessive force. However, the only bearing to worry about is the top ball bearing. The rest are rollers so the slight movement of the shaft won't affect them. And this top bearing is sized to take significant forces. Unless you do beat the living bejeesus out of the crank, it is unlikely that you will ruin the bearing. In all probability you will damage the nose of the crank first.
Firmly tapping the top of the crank is an approved method for removal of the flywheel so with a little respect and care, removing the driveshaft stub by this method poses very little danger to the bearing. It most likely won't come out with the first few raps so the hitting must be continued for some time. Last time I did it, I belted it a few times, walked away and did something else, then returned for another round.
BTW: that top bearing is a standard bearing used in the rear end of some Ford Vehicles. I have pressed them off the crank with a 60 ton (because 10 tons is not enough) press and not damaged them. This involves supporting the outer race and pressing the crank which puts the full load against the balls and races. Hitting the crank with a hammer is nowhere near the force needed to remove the bearing so again, the danger of damage is low.
