driving boat on trailer
isis
I have a 20 foot deep v hull boat.I would like to drive it on the trailer like i do with 14 ft aluminum but in the river the tide runs fast.I like to do it short and sweet.I have guide poles on the smaller boat trailer and it works out good and thing about them on the 20ft trailer.Can this be done or should i just stick to winching.
Gary H NC
Re: driving boat on trailer
Guide on would be a good idea on the larger boat. I have them on my 21 deep V trailer. I don't power load though.I just coast onto the trailer and winch the last 4 or 5 feet..
tashasdaddy
i have guide ons on all my trailers. with 1 inch clearance. i do idle on, but never faster than that, as it erodes the ramp. powering on is a no, no. having the rear 2 rollers as 12 selfcentering rollers puts the bow where it should be then just line up the stearn the guides will put you where you need to be.
Texasmark
I usually line up 4 or so boat length's directly behind the trailer in slow motion and test the conditions. Doesn't take but a minute to see what is going to happen to the boat when you hit the trailer.
So I adjust accordingly and drive her on; not all the way to the chock (churning up all the bottom and all), just on till she stops moving.
Sometimes, when you have a strong cross wind/waves you come (ease) right up to the side boards (like the boat is centered on the windward one and just behind it), lined straight up with the trailer and wait for the elements to blow/push you past the board. Then, just as the centerline of the boat passes the board, before the keel is centered with the trailer centerline, you give her a push (engine power) and if you get it right, by the time the boat gets to the first keel roller it's lined up for entry.
If there is a strong crosswind, I usually put less of the trailer in the water and drive (bounce) onto my 2' back mark. I had rather drive on in these conditions as if you stop the boat, without the aid of the sideboards and the rest of the trailer, the wind will blow the boat sideways at the tip of the trailer and you have to get out (into the water) and physically align it while someone else cranks.....if you have someone else with you......messy.
If you miss you can back up and try her again. I like to use the roller caps and anything else necessary so that near misses don't gouge the hull. Have alum now and it's no big deal, but when I had glass I wanted to protect it.
I have self centering keel rollers, bunks and side boards which are like tas' about 1" on each side wider than the boat, extended from the fender to the end of the trailer, about 18" high, off the frame.
Your deep v hull is probably the easiest to get centered and lined up. just a natural for a V to fit into a groove. If you don't have a groove for it adjust your bunks and rollers and make one and add side boards if necessary.
Other thing, when I back the trailer into the water, I set the trailer depth so that the boat will naturally float to within about 2' of the chock. That way I have enough trailer exposed so that the hull can pick up the trailer parts and if I come in a bit too fast, the trailer will stop it before the bow hits the chock.
One last thing. I am fortunate enough to have numerous lakes and numerous ramps at these lakes. Usually you can plan your trip for the prevailing wind direction for that day and use a ramp that has the least amount of weather related interference.
Kinda wordy, but sometimes you have to express what you mean (don't know who you are talking to) and it keeps my typing skills honed.
Mark
salty87
it depends on the conditions and the boat/trailer
this is a pic of my neighborhood ramp, it doesn't show the steepness as much as you'd see in person but this is about a 50' drop from top of ramp to water. add current from the dam that's about 400 yards upstream and it makes for a challenge. the steepness of the ramp keeps the front of the trailer pointed high and with the current there's no time to dally with lining up, ya gotta hit it or hit the rocks.
i use my guide posts alot at this ramp
Texasmark
Just a suggestion Salty.
I have a receiver on my trucks for trailer towing. I usually know the characteristics of the ramp before I go so I either use a higher or lower coupler depending upon which way the ramp tilts. With 4 or so inches variation, it makes a difference in attempting to level the trailer; not a lot, but anything helps.
Hear you on get it right the first time.
Mark
kenmyfam
We have never powered on yet. We float her on with a couple of ropes and winch from there. never let us down yet but on very windy occasions we have done it twice to get perfectly centered. My sons friends father is a great believer in the "power on" thing however he has purchased 2 new tailgates for his F150 Ford truck over the last 3 seasons !!!! I did not witness any of these "mishaps" but my 19 year old son did. He told me that the approach speed was way too much and suggested that they put it on the trailer "the same way my dad does" but was totally ignored.
Anyone need a tailgate for a F150 Ford ??? Needs some work. 2 available, both the same colour !!!
Texasmark
Gotta laugh Ken. That can happen.
Mark
