Re: Drop Shot bass fishing
Hey guys,<br /><br />Just when i though i had the boat fixen in my grasp....BLAM.<br /><br />I went out and bought the 30 S.S. bolts,nuts and washers to fix it with.<br /><br />Then i looked at the bottom of the boat one more time and found out it has 50 B,N,and washers...RRRRRRR
<br /><br />Oh well...I got a head start. By the time i get those in i will have enough $ for the other 20.<br /><br />Bkelly,<br /><br />Yea its a saltwater gimmic for trout and other fish (mostly trout).<br /><br />It is a jig head with a grubb body floated under a cigar bobber or cajun thunder bobber rig so that the jig/grubb bounces just above the grass. TROUT KILLER. you just do the same as with a jig....but the bobber imatates the sound of feeding trout....witch draws in other trout,and so on.<br /><br />The reverse za-bee-da part is with "dog on carpet style gung fu" the jig/grubb is kept above the grass because of the pull of the rod instead of hanging under the bobber.<br /><br />The butterfly knot is a killer one...its just takes a little more work.<br /><br />Cross the line once to make a loop<br /><br />take a toothpick (or match...something of that size) and lay it across the line where it crosses itself.<br /><br />Turn it about 7 times (twist the toothpick up into the line) so there is several twists on eather side of the toothpick.<br /><br />then stick the top of the loop into the hole where the toothpick is....pull it through and pull the line on each side tight.<br /><br />It makes a real pretty knot with a kinda noose deal on the top and bottom of the loop....real strong too.<br /><br />It gets easier with a little practice.<br /><br />A shoafin monk should always be proficent in " bounceing monkey style gung fu "<br /><br />In my 12ft jon, my daughter ripped a minnow from my flavor saver...up the side of my sniffer...and bounced it off my eyebrow
. How i did not get hooked i do not know....." bouncing monkey " saved the day once again! You can't use " hidden dragon style gung fu" on your daughter...so ya just gotta grin-and-bear it.<br /><br />Luckywood.
