Drum cable steering conversion
jvanhees
I am looking at purchasing a 70's evinrude 40hp outboard for my project....but the steering system is the drum cable type system. I would like to get rid of that and move to the cable/teleflex type system.
What parts do I need to look for, in a used teleflex system?
Do I need to pick up as little as this? Teleflex Steering Helm with 14' Cable | eBay
It seems I would need something that hooks to the motor. I would rather not buy a new teleflex system if possible. :confused: Thanks for any and all help. I am still researching the forums as well.
jvanhees
Re: Drum cable steering conversion
Or....after looking at what these cost a little more....maybe I need to keep looking for another motor. How much $$ can you normally find this used system, all parts I need, for?
Watermann
Find an glass donor with a good motor and all the steering would be the easiest way for sure then you would know it's all good to go working with each other. Plus you get to put an old rot bucket glasser out of it's field boat misery.
jvanhees
Actually that is what I am doing. The boat is being scrapped by the owner for me as soon as I tear everything I want off of it for cheap. Getting some seats and a tach as well. Steering is the drum system tho. Hence why I'm wondering what parts I will need.
Watermann
Take what ever he's willing to give up! Is the motor included as well so you'll have the steering linkage and tilt tube parts?
F_R
In addition to the helm and cable, you would need a transom mount support tube for the aft end of the cable, and an attachment to connect it to the motor.
Gotta tell you this though. While it is possible to make it work, you won't like it. It is nearly impossible to get it to steer full arc and not interfere somewhere when tilting the motor. Give me the drum type steering any day on an old motor that doesn't have a built-in tilt tube. There is not a thing wrong with drum/cable/pulleys steering if installed correctly.
jvanhees
Water this motor is the motor/glasser I speak of in the first post.
jvanhees
So you are saying it's not an easy fix to convert? Even if I find used parts? That's basically what I need to know.
Thanks guys
F_R
I'm not saying it is difficult, I'm just saying it will work but not well.
boobie
That motor wasn't designed for through the tilt tube steering. As F_R said the rope and pulley is the best for it.
Fed
I had a boat with a transom mount like F_R mentioned, it clamped around the outer 'ram' and had a ball & socket to allow for tilting. The inner ram bolted straight to the tiller with another ball & socket.
Check it out at teleflex to find out what you're looking for but I think it would be hard to find all the right set up secondhand.
jvanhees
Ok guys thanks for the input. I think Im going to elect to pass then, and wait for the right setup....right setup being the outboard, controls, and steering (non drum) to all come from the same rig...so I know they work good together.
Sorry guys, Im still learning!
boobie
No problem what so ever. If you don't ask, you'll never know.
