Dry Joint Exhaust Manifold Conversion
kkalsch
I have a 2003 4.3 MPI Alpha Gen II -and its time to replace the manifolds and raisers. I do not have the dry joint system......but is it possible (without to much trouble) to convert to the dry joint system?
Thanks
KK
achris
More fish than mountain goat
Re: Dry Joint Exhaust Manifold Conversion
yes, It's actually very easy, all you need to do is buy the manifolds, elbows and gaskets all at the same time. They are just a straight swap.
You need 2 of each of these
Exhaust manifolds are -864612T01
Manifold gaskets 27-99757
Elbow Gaskets (for seawater cooled engines) 27-864850A02
Elbows -864309T01
kkalsch
Thanks -my current system has 3" spacer?
achris
ok, then you'll need Spacers too... Part number is -864929A3... (2 of again)
Don S
Do you boat in salt or brackish water?
kkalsch
Sorry for the delay Don S .....yes- Salt water -"Crystal Coast" and the boat stays in the water -
kkalsch
I just did the research..... to convert to the Dry Joint its $500.00 more -do you think its worth it? (I have 2 engines...so that's a $1000)
