Dry rotted floor
Camcorder77
I have a 86 skeeter starfire and my stringers are all rotted and i dont think I'll get a good one out to use as a guide. Is there any info out there on the specs for this boat?
welcome aboard
pretty sure your transom is also gone
measure your existing stringers, make cardboard templates, etc before you remove anything, take lots of pictures. then simply remove everything down to the hull, grind for a few days and then build it back up.
I recommend a few things, first PM a mod to move this to the restoration forum http://forums.iboats.com/forum/boat-repair-and-restoration/boat-restoration-building-and-hull-repair
next, read links 14, 3, 4a and 4b http://forums.iboats.com/forum/boat...r/295740-how-to-s-and-other-great-information
jbcurt00
None that would help recreate a stringer.
Run a straight edge or a string from point A to point B and measure down to get the contour of the hull for the bottom edge of the stringer.
Baylinerchuck
Welcome to iBoats, you came to a great place for information on your build. Like Scott said, there are a lot of resources here, and unfortunately you're not going to find any templates for specific hull parts. Make sure you takes lots of pictures and measurements as far as location of parts. If you have bulkheads that intersect the stringers you could use a "story stick". See post #161 on my restoration link below as a basic idea. Once you get a basic shape scribe the bottom, trim the top, then you could use the same method for the stringers. Just another idea as there are lots of ways to skin a cat, but this is how I like to do it.
Good luck, and post lots of pictures when you can. We love pictures!!
:welcome:
Woodonglass
Go to a Local Appliance store and have them give you some refrigerator boxes. Cut the cardboard and tape it together to get 10" x how ever long you need. Use a pencil compass but tape a Medium tip Magic marker
to it and then scribe the bottom of the hull putting the mark on the cardboard. Cut the scribed mark to shape and then determine where the top of stringer should be to make a flat level top. use this template to make your stringers from laminated 1/2" ext. grade plywood. Remember the scribe line doesn't have to conform perfectly to the hull. When you PB the stringers in it will fill any/all gaps.
Hopefully this crappy drawing will show what I'm talking about... Boat Scribing.jpg
