Re: drying out floatation foam
I found I could fiberglass to polyurethane and it worked pretty well.<br /><br />Polystyrene (coffee cup white Styrofoam) is lighter, doesn't absorb water, and depending how you buy it it's probably cheaper. The down side is it doesn't stick to the boat, and polyester resin eats through it, so you have to rely on the boat holding together enough to keep the foam inside. I'm not sure how epoxy would work on it.<br /><br />Most of the floating docks I have seen have either blue or orange foam, which I think is polypropylene. Polyurethane isn't good for docks because it absorbs water, as you know.
