Melted temp sensor but pumping water out of indicator. Removed Thermostat to check and plenty of water moving through cavity for thermostat. Please help & Thank You in Advance.
When last did you change the impeller? Water might flow with an old impeller but it might not be enough, the tell tale need to be strong and a lot of water needs to pump out the "sneeze holes" just under the cowling ...
