Have a Suzuki DT115 2 stroke that is giving us (myself and mechanics) a fit. At slow idle, the motor will just cut off just as someone cut the ignition switch off. It will also do this at WOT. No sputtering, spitting etc. Marina mechanic has replaced: kill switch; ignition switch; check fuel pump and replaced diaphram; replaced plugs and check flywheel sensor. Nothing seems to fix the problem. Anyone had this issue before? It's prime fishing time here in the Carolinas and I'm hesitant to take the boat out anymore. Disabled Vietnam Vet and can't afford to repower at this time. HELP!!
