dt25 water in exhaust housing is it normal ?
bigrob87
i have a 81 Suzuki dt25 i replaced the water impeller and now that i have i noticed that there is moisture in the exhaust housing is it normal ? im new to boating any help will be nice
robert graham
Re: dt25 water in exhaust housing is it normal ?
I'm not exactly sure what/where the "exhaust housing" is, but during normal outboard operation there is moisture and water just about everywhere. If your motor is running and cooling good, then maybe there's no problem? Can you post a photo of motor and location of the "moisture"?
bigrob87
yes i will take pics tomorrow so you can see them. there is a plate that you remove to disconnect the shift linkage to remove the lower unit and you can see the in side of the exhaust there is moisture in there.not sure if helps you any but will have pics up tomorrow
bigrob87
hear are the pics i hope this will help
