DT4 cooling problem
Gypsy 15
Hi I have a Suzuki DT4 1998 that I intend to use as a spare for my gypsy 15,
when running in the tank only a dribble of water comes out of the pee hole.
I have removed the bottom leg and striped the impeller out it seems to be in fair condition but I will fit a new one on re assenbleing. I can blow through the pee hole tube, and the male tube to the impeller with ease. I blew some smoke through the system and it seemed to come out 1/2 way up the leg, there is no sign of water having been in the lower leg any help Please
Jon
triumph190
Re: DT4 cooling problem
Check the thermostat if you have not already. If it is stuck closed then it will not allow water to pass.
deejaycee_2000
The DT4 only have a sputter and not a strong stream, this is normal ....
