dt55 pilot jets
nofun2
I'm cleaning the carbs, and can't get a small peice of wire through the pilot
jet. Is the jet have a hole straight through, or is there a restriction in the jet??
thanks bob 1986 Suzuki dt55 :confused:
mphelle8vld
Re: dt55 pilot jets
If you mean from the outside/top of the carb, that hole is plugged. You have to remove the jet to see the metering holes in the sides and bottom of the jet
