nwslider
Thread starter- Joined
- Feb 16, 2009
- 9
I have a DT55 1986 Suzuki. The water temp light is on when starting the boat cold and stays on, good stream of water from the pee hole and water spitting out the back. Runs good and strong until you get to a certain RPM, don't have a tack but trying to throttle up over about 10mph the engine sputters as the rev limiter light comes on. Can run like this for over 5 min. should be up to temp, water coming out of pee hole is warm at best, no where near hot. Just had water pump and thermostat replaced week or two ago and this is the first time out, well second day, the first day it ran fine all day no problems. Kept the boat in the water at the marina and the next day this all starts up.
Is the next best thing to check the sensors? Were are the sensors? Is there a place online I can down load a service manual? My buddy and I are pretty good with a wrench, used to build and race our own drag cars.
Cheers!
Cheers!
