dt75 carb problem
Central Bears
since i didn't get a reply the first time,i read jb"s how to ask a question.Looked thru forum's and found some of the same problem's with my motor.thank you,very helpful.mine is a 1996 dt75,started and ran good,stopped afew times and on last stop wouldn't start.pulled cowling and fuel shot out of the bottom carb thru a hole when primer bulb was squeezed.Some of the forums said it could be a stuck float or gummed up needle in the float bowl?If carb needs to be cleaned,should i do the one are all three?Just like some of you i did my time in the service,ran a sniper unit in panama in the late 70's.When i didn't get a response the first time i felt slitted.just want to take my son fishing.Coach.
JB
Re: dt75 carb problem
Do all three carbs, Coach. One carb in trouble would not prevent the other two from starting.
