DT75 - hole in top of piston
Cottonp
1985 DT75...running fine...then bogged down. Took off head to see 1/2 inch hole in top of #2 piston.<br />Not sure why...??<br />Is this engine worth repair if I do work myself?<br />Can you get parts online?
abe hatt
Re: DT75 - hole in top of piston
hello, i have same motor #2 piston overheated and scored cylinder wall.I had three estimate's all were about $1850 to rebuild.I think I could do it myself for about $900.might check the oil injection.I am going to pre mix my gas from now on
FHARVELL
A burn hole in the top of the piston is usually caused by a lack of adequate fuel,probably caused by a defective fuel pump. The most common problem is a tiny pin hole in the the diaghram or a bent check valve inside the fuel pump. Such a small hole will permit gas to enter the crankcase and wet foul the spark plug at idle-speed. During high-speed operation, gas quantity is limited, the plug is not foul and will therefore fire in a satisfactory manner. If the fuel pump fails to perform properly, an insufficient fuel supply will be delivered to the carburetor. This lack of fuel will casue the engine to run lean, lose rpm or cause piston scoring
