I have a ?99 Suzuki DT85, and the pump impellor failed. Got a new one and started putting it back together simple enough, til I got the shaft (so to speak).
How the heck do you get the clutch rod (long vertical rod from gearcase to under head) to line up with the clutch shaft (short horizontal rod from shifter arm to hole in top of clutch rod)????
The shaft and rod both come together directly under the head, and there?s no way to see in/down there to help line them up. Push the shaft out of the way with a needle-nose while sliding the lower-unit/clutch rod slowly up, and then gently jiggle and pull on the shaft in hopes that it goes into the hole at the top of the rod? nope, try again.
Started the re-assembly about 2:30 yesterday afternoon, and gave up at 7:30 (missing dinner!). I?ve twisted and turned the two of them so many times last night, I saw them in my nightmares.
I'm not even gonna guess if the water-tube grommet will end up where it's supposed to.
There?s gotta be a secret to it! Any ideas?
