Dual Plane Intake and Carb Base Plates/Gaskets
76SeaRay
I haven't found a discussion on the correct gaskets to use when running a dual plane intake with a 4 barrel. So, here goes a thread on the issue:
Both Holley and Rochester (QJet) have gaskets that use individual holes for the 2 primaries and 2 secondaries (4 total). There are also gaskets that are "open" across all the primaries and secondaries. The open gaskets means that there is a gap between the base of the carb and the center of the dual plane intake allowing cross over to occur. Using a 4 hole gasket prevents this so it would seem that is the route to go. However, that means there will be unsupported portions of the gasket in the opening of the dual plane intake (potential to age and fall into the intake?).
Admittedly, the cross over flow is probably pretty small due to the thin gasket material but what happens if you run a thicker (say 1/4 inch) insulating gasket. Cross over would likely increase and I have heard that some engines don't perform as well. However, it has also been mentioned that the thicker gasket, which helps keep heat out of the carburetor, would also increase the plenum size and raise the secondaries out of the designed plenum area avoiding secondary disruption of air flow in the plenum.
Finally, there are metal shims that are used to prevent heat transfer as well (but those seem to be all 4 hole plates) to add into the mix.
Any thoughts and opinions or real life examples on which way to go with it?
depends on your specific intake.
assume an edelbrock. the dual plane divider has a gap between the divider and the carb so there is some cross over, which is needed for signal back to the carb at low RPM's
the best combination I have found with a small block and dual plane manifold.
a 2" spacer under the carb. one that transitions from 4 holes to two slots. dont worry about the small gap in the divider. the extra plenum volume helps with low to mid-range RPM torque
76SeaRay
So, I decided to go with a 1/2 inch 4 hole spacer. Top to bottom, QJet, 4 Hole Spreadbore Thin Gasket, 1/2 Inch 4 Hole Spreadbore Spacer, Open Spreadbore Thin Gasket, Dual Plane Manifold.... I will see how the performance works out with just a thin gap of crossover. Easy enough to change if it doesn't work out...
