woodnknots
- Joined
- Oct 20, 2006
- 96
I have a dual 55 hp Johnson setup with what I think is a MT-3 (maybe MT-2 given it is a 1978) dual control setup. I've only had the boat a few weeks, and the throttles have always interfered with each other when they passed around the neutral position (I fixed that part, I think), but now today, I can't shift the starboard motor to reverse. The throttle lever just stops.
I pulled the cables off the motor, and the lever operates smoothly.
I checked the shift lever on the motor, and the throttle. Both are operating normally by hand.
I removed the cables from the throttle controls, and they both slide freely by hand.
I believe I have gotten it down to the throttle control lever, but my question is is there a way to pull this thing apart and repair it? I think that the middle part of the control (with the large nut and teflon washers) is the part that is binding when it has the tension of the cable on it. Has anyone else seen this problem? I really don't want to shell out the $600 for a new control, and I wanted to take the boat out for Labor day!!
Thanks,
Dave
Thanks,
Dave
