Dues this look normal??
mokaction
Just hooked up my computer to the engine and this is what I got. Looks like it is alitle hot?? What do you guys think??
Thx in advance,
Larry
Engine Monitor
Monitor Item Result Unit
Engine speed 0 r/min
Intake pressure 100.15 kPa
Intake pressure 29.65 inHg
Atmospheric pressure 1001.5 hPa
Atmospheric pressure 29.6 inHg
Battery voltage (12-16) 13.1 V
TPS voltage (0.5-4.5) 0.679 V
Throttle valve opening (-1-90) -0.5 deg
Fuel injection duration 0 ms
Ignition timing - deg
ISC valve opening 67 %
Engine temperature (below 120) 69.5 ?C
Engine temperature (below 248) 157 ?F
Intake temperature (below 70) 29 ?C
Intake temperature (below 158) 84 ?F
Oil pressure (below 842) 61.3 kPa
Oil pressure (below 122) 8.9 psi
Engine stop lanyard switch OFF
Shift position switch ON
Dual engine system switch OFF
Shift cut-off switch OFF
Overheat thermoswitch ON
Data Logger[Data comparison graph]
Engine speed[r/min] Battery voltage (12-16)[V] TPS voltage (0.5-4.5)[V] Engine temperature (below 120)[?C] Intake pressure[kPa] Oil pressure (below 842)[kPa]
1100 14 0.84 69 89.8 780
1200 14 0.88 68 88.8 780
1050 13.5 0.8 68 89.3 780
750 13.5 0.66 69 83.9 780
700 13 0.66 72 83.4 780
700 14 0.66 69 80.9 780
750 14 0.66 68 84.4 780
650 13 0.66 56 76.5 780
900 13.5 0.66 58 90.8 780
900 13.5 0.66 61 85.9 780
650 13 0.66 52 83.4 60
950 14 0.66 54 78 60
900 14 0.66 58 79.5 60
JB
Re: Dues this look normal??
What engine, what conditions?
rodbolt
well I can tell its a four stroke anyway and the engine had been run but is off when the data was stored. kinda makes most the data usless but all the numbers look about right for an F150-F250.
showes all the sensors are inputting usable data to the ECM.
the overheat temp switch on is a concern. could be a bad switch or it could be overheating.the F150,F200 and F225 take a special procedure to test the overtemp and oil pressure alarms.
several conditions must be met to actually set the alarm.
next time set up the data stream to only read metric units or english units. makes it a lot easier.
mokaction
Sorry, Ya, it is a f200txra Just rebuilt it. Also I forgot to put the 69J-14664-00-00 GROMMET, WATER SHUT when I put the heads back on. The manuel didn't show them on the motor when I was rebuilding it.
Larry
