Just hooked up my computer to the engine and this is what I got. Looks like it is alitle hot?? What do you guys think??
Thx in advance,
Larry
Engine Monitor
Monitor Item Result Unit
Engine speed 0 r/min
Intake pressure 100.15 kPa
Intake pressure 29.65 inHg
Atmospheric pressure 1001.5 hPa
Atmospheric pressure 29.6 inHg
Battery voltage (12-16) 13.1 V
TPS voltage (0.5-4.5) 0.679 V
Throttle valve opening (-1-90) -0.5 deg
Fuel injection duration 0 ms
Ignition timing - deg
ISC valve opening 67 %
Engine temperature (below 120) 69.5 ?C
Engine temperature (below 248) 157 ?F
Intake temperature (below 70) 29 ?C
Intake temperature (below 158) 84 ?F
Oil pressure (below 842) 61.3 kPa
Oil pressure (below 122) 8.9 psi
Engine stop lanyard switch OFF
Shift position switch ON
Dual engine system switch OFF
Shift cut-off switch OFF
Overheat thermoswitch ON
Data Logger[Data comparison graph]
Engine speed[r/min] Battery voltage (12-16)[V] TPS voltage (0.5-4.5)[V] Engine temperature (below 120)[?C] Intake pressure[kPa] Oil pressure (below 842)[kPa]
1100 14 0.84 69 89.8 780
1200 14 0.88 68 88.8 780
1050 13.5 0.8 68 89.3 780
750 13.5 0.66 69 83.9 780
700 13 0.66 72 83.4 780
700 14 0.66 69 80.9 780
750 14 0.66 68 84.4 780
650 13 0.66 56 76.5 780
900 13.5 0.66 58 90.8 780
900 13.5 0.66 61 85.9 780
650 13 0.66 52 83.4 60
950 14 0.66 54 78 60
900 14 0.66 58 79.5 60
Thx in advance,
Larry
Engine Monitor
