Re: Dumb Question
It's a 98' merc 25, 2-stroke that I got used about 4 months ago, right off the bat put $500 in service (tune, link & Sync, waterpump assembly, lower service, plugs, t-stat, water jacket gasket after breaking bolts for t-stat, and carb rebuild). Before I even paid for the motor I did a compression test right infront of the guy....125 even on both cylinders. Took it home and ran my bore scope in the cylinders...you can still see the hatching in the walls from the factory. The tops of the pistons are black with carbon and it's never had a fuel treatment or seafoam until I got it. I want to run the full mixture to "decarb" the motor then will problably run maybe a 1/4 to 1/2 mixture to maintain that. My question was, is the Seafoam compatable with other treatments, since the Enzym is already in the full tank and would the full can at first and a lower dose every fill give me the results I'm looking for?
